New Dual Disc Part Numbers!
#83
This is moving up my mod wish list, and I'm pulling part numbers now. I had some trouble with the master cylinder. The 45170-08B is no longer available via the usual suspects (surdyke, kutter, etc.), but 45170-08D is. I think the 08D is a direct replacement based on the OEM parts finder. Does anyone know for sure?
Second, finding a right side caliper for my 2013 FXDB led me to discover the FXDL uses 11.5 rotors. My FXDB uses 11.8. Since I intend to buy a matching Lyndall rotor for the right side, I want to be sure I'm getting the right one. Has anyone used the FXDL part numbers on a FXDB with 11.8 rotors? What part number did you use for the caliper?
#84
Where did you get the idea that the 14-15 FXDL used 11.5" front rotors?...all Dyna rotors shown below 11.8
#85
Thanks for getting me over that hurdle.
Next question is that brake line block under the lower tree. I can't find a part number on any of the OEM parts finders. Do I need a different one for dual disk (ABS), or is it included with the brake line assembly (41800296A)?
#86
"so I tried to do a comparison of calipers to see on the HD website, and found the FXDB caliber fits "Fits '08-later Dyna® (except '14-later FXDL)."
#87
Yes, it's included in the 41800296A Assy and correct if you have ABS
Your looking at "Parts & Accessories"...they showing "Upgrades", Red and Chrome ones for single front brake models they don't list any for dual front models. So even though that Red or Chrome one will fit the Left Front of a FXDL, It's not a complete set...so it doesn't "Fit".
#88
For a 2013 Street Bob - with ABS, I have compiled a Parts List as follows. Is this correct? Do I need to order any other parts or delete some parts from this list?
Quantity Part No. Description
1 45500271 SLIDER,RH,F RT FORK,BLACK
1 41300002 CALIPER ASSY, RH, FRT, BLK
1 44163-00 BOLT, CALIPER MOUNTING, UPPER
1 44160-00 BOLT, CALIPER MOUNTING, LOWER
1 46717-10 BRAKE DISC ASSEMBLY
2 41731-01 GASKET (crush washer/gasket that go on either side of the brake line fitting when bolting into the caliper)
1 45170-08D Master Cylinder
1 41747-82A FITTING, MASTER CYLINDER (this is the bolt that fits the brake line to the caliper)
1 41800296A Brake Line Assemblly
1 Brake Pad Set
No Lowrider in this country, so it's difficult to get any help from the dealer.
Thanks.
1 Brake Pad Set
Thanks.
Last edited by ZeroThoughts; 08-28-2015 at 05:45 AM. Reason: Format & spelling correction.
#90
