New Dual Disc Part Numbers!
#61
I can confirm that all you really need to replace are the fork sliders. I completed this mod some months back. All the guts in the forks bolt up 100%
I had originally gone to dual disc using fat-bob sliders w/ touring brembos (machined to fit). Once the lowrider sliders were available, I ordered them up and made the swap. Went with jay-brake 6 piston calipers.
Just get the sliders and new seals. You could even just replace the right slider if you want to save as much $$$ as possible. I ordered both because the lowrider slider is aesthetically different at the caliper mount than the stock left slider from my '09 FXDC... Just nit-picky, would have worked perfectly using my stock left slider and the right from the lowrider.
good luck
good luck
#63
The front brake does the vast majority of braking for any motorcycle. In a maximum effort stop on a cruiser style bike, the front brake provides roughly 70%-80% of your stopping power. In a sportbike, at the point just before a "stoppie" begins, the front brake provides 100% of the braking effort.
If you're not using your front brake on every stop, then you're not effectively utilizing your brakes. And, even more importantly, if you have never developed the habit of using your front brake on every single stop, if a car ever pulls out in front of you and you have to do a maximum effort stop (or a "panic stop" to use old terminology), then you are going to lock up the rear brake and crash.
Guaranteed.
I would strong, strongly suggest you take a rider's training course, and really focus on the braking exercises. Yes, you can certainly buy a DVD and do what it says, but there is no substitute for having an expert stand right next to the bike while you lock up the rear tire. They'll teach you how to do it correctly, using both the front and the rear.
Take a class. Really.
oldbie (09-22-2016)
#64
#65
Wow! I just got served. I didn't realize the benefits. I guess after over 80k miles I need to take a riders course watch some videos and add extra brakes up front. I have no idea how to ride. I guess I'll leave out the part that I would buy a chop without front brakes. Maybe I should get a bike with abs also. I'm guessing this would also be a bad time to mention I wear shorts to work with my lack of riding ability. Lol.
#66
Wow! I just got served. I didn't realize the benefits. I guess after over 80k miles I need to take a riders course watch some videos and add extra brakes up front. I have no idea how to ride. I guess I'll leave out the part that I would buy a chop without front brakes....
Whether or not you know how to ride, I have no earthly idea.
And, obviously, you're free to to whatever you want.
Carry on.
#69
Finally have the dual disk setup on my 2006 Street Bob. Everything lined up fine with no spacers needed. I did get a new brake caliper for the left side to match the newer version that the low rider has...mostly because I'm a little OCD and it would drive me nuts knowing about it.
