New Dual Disc Part Numbers!
Old 10-26-2016 | 02:15 PM
bowmanvillejim's Avatar
bowmanvillejim
another question on calipers. can you install calipers off a bike with ABS onto a bike without ABS without any problems ???
  #132
Old 10-26-2016 | 03:10 PM
cvaria's Avatar
cvaria
doesn't matter. Crazy as it sounds, the caliper is not really involved other than doing its normal job.
  #133
Old 10-26-2016 | 03:14 PM
bowmanvillejim
Originally Posted by cvaria
doesn't matter. Crazy as it sounds, the caliper is not really involved othe than doing its normal job.
thanks, thats what I thought
  #134
Old 10-26-2016 | 03:19 PM
cvaria's Avatar
cvaria
Originally Posted by Jackpoticorn
What is the benefit to ordering the black set 45500273 vs. ordering just the RH black slider 45500271? Is it the same slider? Going on a 2014 Street Bob
Cant answer that one. i would say none other than price. But, the mounts are shifted around on the various bikes. Check here and compare the bob sliders to the low rider.... http://partstream.arinet.com/Mobile/...FEGHaZ5Q2.html
Multihdrdr is out there watching and will chime in at some point.
  #135
Old 10-26-2016 | 07:46 PM
Jackpoticorn's Avatar
Jackpoticorn
Hmm that link isn't working...I am thinking the single slider is off the LRS so it SHOULD have the same mounting points as the Street and LR, the Fat Bob is the one with different mounting tabs as far as I know...
  #136
Old 10-26-2016 | 08:15 PM
cvaria's Avatar
cvaria
Sorry
http://partsfinder.onlinemicrofiche....artsfinder.htm
  #137
Old 10-26-2016 | 09:28 PM
multihdrdr's Avatar
multihdrdr
Hmm...Didn't like your answer on 6/10?
Slider questions!
Doing this on a '14 FXDB - what is the difference between part # 45500271 SLIDER RH FRT FORK BLACK and part # 45500273 FORK SLIDERS BLACK FXDL??? Which do I need? Is it as simple as the first part # is just the right side while the second part # is two new sliders?
My mechanic said even if I got a new black right hand slider, it would be wise to powder coat both the new right side and old left slider so that they match exactly. Is that just him trying to jack up the bill or will they be noticeably different shades of black?
Valid point about questioning if the "Blacks" match. Buying the "Set" would insure that, but Suede has a 2014 FXDB also and commented...
I used "45500271, SLIDER,RH,FRT FORK,BLACK", it looks exactly like the other one.
Same Slider in Kit
BTW, that Black "Sliders Only" kit doesn't pop up @ H-D dot com currently. Only shows Chrome and both Black and Chrome in the "Full" kit
Also FWIW (for others)... besides color, I think the slight casting change was in 2012. So 2012-later looks a little different than the earlier ones.
Jackpoticorn (10-27-2016)
  #138
Old 10-26-2016 | 09:46 PM
multihdrdr's Avatar
multihdrdr
ok I have a question about brake caliper assemblies. I have picked up a set of 2016 Lowrider sliders. do I have to use the calipers for the 2016 LR or can I use a set off an street glide ?
People do it ...use V-rod/Touring Brembos on 06-later Dynas, but it's not a "proper" set-up.
Touring Brembos used on 06-later Dynas will move the pads .150" outwardly on the rotor radius on the same 11.8" (300mm) rotor. That will put the pads out on the chamfered/radiused edge of the rotor or slightly past the edge
  #139
Old 10-26-2016 | 11:26 PM
kbiker76's Avatar
kbiker76
I just installed my sliders from a 14 lowrider powdercoated black. Will be finishing it off this winter with speed merchant radial mounted caliper brackets and 2011-16 gsxr 600 brembo calipers.
  #140
Old 01-22-2017 | 09:33 PM
hsr's Avatar
hsr
If anyone looking to do this conversion is interested in a pseudo parts kit, I have this available in the classifieds: https://www.hdforums.com/forum/dyna-...49mm-dyna.html
Quick Reply: New Dual Disc Part Numbers!
