New Dual Disc Part Numbers!
#101
#102
I think you'll just use your stock spacer.
Your stock spacer for your 2012 FXDC:
11804 SPACER axle | GP4/GPM/GV4/GX4 $8.63
http://www.granitestateharleystore.c...%7eLACED%5cGV4
Stock spacer for the 2014 FXDL:
11804 SPACER axle (1-ABS, right only) | GNM/VAM/VCM $8.63
11804 SPACER axle (2-NON-ABS, right & left) | GNM/VAM $8.63
http://www.granitestateharleystore.c...eSLOTTED%5cGNM
#104
Replace the ABS bearings in the 14 FXDL wheels with standard bearings (like on the other side of those wheels) and re-use your existing spacers
OR
If you say, "But I hate to change out those New bearings that have never even been used" ...especially if you have to pay someone to replace the bearings.
Then you could use Reduced Length Spacers against those wider ABS bearings (Left-Front and Right-Rear). Then whenever you would replace bearings because of maintenance or repair, you would use Standard bearings and use your original width spacers.
PM me if you need info on those Reduced Length Spacers
#105
Ohh! very good points!
As mentioned, you'll be using the stock spacers from your 2012 FXDC non ABS.
OR
OR
#107
OR
OR
#109
OEM Wheel wise...
A 2014-later "Low Rider" is a direct fit.
You can use a 13-spoke "Mag", but will have to deal with it having a narrower hub and possibly (depending year and model), enlarging the center section of the wheel for your 25mm sleeve/axle. It's done all the time.
#110
Stock wheel (depending on what you got) should work. There's a cover on the stock spokes that comes off. Most mag options work, too. The Switchblades WILL NOT work.
