What would you do ?
Old 03-23-2007, 07:49 PM
cjackson's Avatar
cjackson
cjackson is offline
Default RE: What would you do ?
Thanks for all the input. You guys are right. I wouldn't structurally alter anything. I could probably get away with lowering the suspension because that is a common procedure. Yes I plan to keep anything stock that comes off. Changing the bars usually means changing the controls , I don't know, that may be taking it to far if down the road someone wants to take it back to stock. No changing sheet metal can happen.
Maybe radical was to strong of word to use. Mild custom sounds better. Just enough to set it apart but not enough to destroy the limited addition value. The Arlan Ness Headlight is still in. ( so is the conical pointed air cleaner )
BRIT206
10-15-2018 07:08 AM
CrazyHog
09-08-2013 02:22 AM
Rick Lees
07-01-2011 09:30 AM
Asphalt_Eater
Custom Models
08-15-2010 10:38 PM
County98
02-18-2010 09:17 PM
Quick Reply: What would you do ?
