Idle stall issues
I have a 2012 Superglide. Occasionally when starting it has a delay then starts, but clears my display screen and has a idle at about 6000 rpms. Today after reaching a stop it just stalled out. It stalled at every stop I made. I could prevent the stall by revving engine. Any thoughts on what could be causing this? Thanks in advance.
Do you mean 600rpm not 6000rpm? I had similar problem on my 07, after PV flash, never had problem once. Early model has idle stalling problem, please read this http://www.pdf-archive.com/2011/03/15/tt410/tt410.pdf
Your 2012 shouldn't be affected I guess. How low was the outside temperature when it stalled? It could also be the weather.
