Dealer install of SE Pipes & AC
Decided on which model to puchase, a Low Rider and am thinking of just having the dealer install the SE pipes and AC along with EFI Map. Parts and labor for the pipes, AC, SERT, Dyno about $800. Not sure why he requires me to buy the SERT and have the dyno tune. Isnt this a common setup that they should just be able to download to the EFI. Don't the dealers have the equivalent to a "master key" to download a map to any EFI and not require a dedicated SERT plug to be created with my bike's VIN?
B
B
RE: Dealer install of SE Pipes & AC
If you are really getting slip-ons, SE cleaner, SERT, and dyno tune for $800 including all labor, that sounds like a very very good deal to me. Dyno tune alone runs 250-300, probably higher on sert, sert is at least $350, AC is $140, pipes maybe $250? If all labor, dyno and a SERT are really included for that money - I'd jump on it.
They are able to connect to the ECM only to upload pre built maps that the MOCO sells you, and they will always be lean to your build.
And like Glide05 said.. it sounds like a fair deal
...or you could just put the pipes/ac/PCIII on yourself and save some serious cash. I will get a dyno tune when I need to, but right now I don't need to. If you just listen to the motor and check the plugs you can get a pretty good idea of how its running! Good luck.
SE Pipes - around $250 (average for various model choices)
SE intake - $140
PCIII - $300 (approximately)
Dyno - $250
Total - $940
I don't know - seems like a pretty good deal. Even without the dyno and using a generic map, the cost is $690. Pretty good price to have someone else do it and get the dyno done.
SERT cost isn't even listed in the catalog, but I think its around 400 or so.
edit - just looked up MSRP for the SERT - $459.95
SE intake - $140
Dyno - $250
Total - $940
Dyno is better, but not totally necessary, in your case. There are canned maps that come with the SERT that are designed for use with SE products.
I recently purchased a SERT and have been advised to try out some of the canned maps, see how they run, tweak if necessary, THEN think about a Dyno if still not satisfied.
That's what I'm gonna do.
HOWEVER, as previously stated, if you can really get ALL of what you listed done now for $800, might as well go for it, because that is unbelievably cheap...
LdyMjo
03-31-2008 03:33 PM
Ace07FXDL
06-17-2007 03:47 PM
If I'm only doing pipes and A/C do I need to buy a SERT or can Dealer just re-map ECM and Dyno tune?
Ace07FXDL
05-27-2007 10:51 PM
