Tank Lift?
#31
Kevin, can I do a rear lift. Just asking before I mess with it or remove it, I'm sure I'm not the first with this concern.
#32
Received 4,255 Likes
As you know the front lift for the split tanks are far more complicated than the lift kits for the one piece tanks, so, while it may be a bit of a challenge, with some time and effort it may be possible.
#33
#34
Yeah, unbelievably, we took well over a year building prototypes, testing, more prototypes, and then the jigs...what a nightmare.
Regular tank lift-30 minute install...what it looks like-
Split Tank tank lift - 1+ hour install ...what it looks like...every angle, curve, slotted hole, etc. has to be just right-
#35
Great kit, definitely worth it. This has to be the best look for the buck mod I have done so far!
#36
Maybe its the angle that the petcock is attached to the tank? IDK but its a bit of angle, & I was able to position the new hose that DK supplied to best minimize strain & how tight of a turn the hose has to have (as it turns down).
#37
#38
#39
