99 Super Glide Sport project
Getting ready to put alot of it back together.
Most of my stuff is back from powder coating....
front and rear wheels
upper and lower trees
fork legs
some other misc stuff powder cooted semi-black
Got a new ME888 140 mounted up for the rear and waiting on the new front....it was supposed to be here yesterday, but I guess UPS decided I didn't really need it til Monday.
The 3* neck cups are installed and the longer stem is mounted in the lower tree. Drilled the lower tree for a bottom mount headlight. Still have to rebuild the fork legs, install races in both wheels and check end play in the wheels.
After the bike is mostly back together, minus the tank, I am gonna order up some black 15" bars and see if I can be together before March 1st.
fork legs
Got some more done last night....the rear fender and wheel are bolted up, everything is torqued and has loctite on it. The 140 ME888 just fits with like 1/16th of an inch clearance on the belt. All new bearings in the wheels and neck. Also added new pads in the rear caliper. To finish up the rear end, I just have to wire the turn signals and lock up the bottom shock mounts. I put the forks back together and bolted them up....the pic shows the wheel in place with no axle. Also got a bottom mount headlight off eBay for like 10 bucks. Just drilled a hole in the bottom tree so that's done too.
With the short Progressive shocks and the 3* neck cups this bike is gonna be pretty low.
![Icon Wink](https://www.hdforums.com/forum/images/smilies/icon_wink.gif)
Hey If someone with a Low Rider wants to trade......I'm down. Where I ride the roads are flat and straight....there aren't many twisties. Besides I am keeping all the stock stuff....so it's just a matter of switching this and that out. No cutting going on so it'll always only be a few hours worth of work to put it back up in the air like a dirt bike.
Totally not kidding about the cat thing either.
