Injectors
Injectors
Hi all, new to the forum, been reading it for months and thought it was time to register give it a try.
Seen a number of threads regarding the 8 degree injectors.
I have an 06' Wide Glide that I purchased new last June, prior to pick-up I had them do the SEII slip-ons, SE Air Cleaner, re-map, ect.
When I received the final write-up of the work they did I saw a line item for "CART 1450 ST1 Dyna 8 Deg Race" part number 34400-06. Bikes ran great last year, but only put on 1,500mi. Will this solve the problems I'm reading about the 8 degree injectors or am I going to have to have a 25's install at some point?
RE: Injectors
Check this forum link. You need to look to see if you have the 8 degree injectors. Then, if you are having cold start problems, surging or cough/stumbling from stop when cold otherwise known as driveability problems at the dealer,you need to check with your dealer about getting them changed. If you aren't having any problems with the injectors, and many on here have said that they are not, then don't worry about.
https://www.hdforums.com/m_1350336/tm.htm
RED E GLIDE
03-27-2006 01:42 AM
