Mini Tach
RE: Mini Tach
Punisher,if you decide to go with the handlbar clamp type mount,I've got a 67128-04 base bracket and a 67676-04 bracket which I'll donate to the cause. Couldn't use them on my Bob cause the housing interfered with my Windvest. then all you'd have to do is buy a 2 5/8 mini tach kit and the gauge housing which is about a hundred sixty bucks retail.I also bought some extra connector pins to plug into the number three pin on the ecm connector which I will throw in. Those little two inch mini tachs are ok but they are so small they gotta be hard to read and they just look too small to me.
Good Luck
Tom
Good Luck
Tom
Stanger
08-20-2007 12:56 PM
Stanger
08-09-2007 04:48 PM
