11 Street Bob, how large a rear tire?
My stock rear tire (160) has almost had it, (i have maybe a couple of hundred miles left on it safely).
Without having to change anything out, I can go to a 180 correct? Is the 180 as large as I can go?, also are there any options for a slightly 'taller' tire? I raised my suspension to 13in (for my back) but I was hoping to get a tire that will fill that gap a little more than the stock tire does.
Thanks for any input
Bummer re-tire height, that look is just a trade off I had to make due to my back. Thanks for the info!
The Night Dragon is supposed to be one of only a couple of 180's that work on the stock Street Bob wheel. Here's a fuzzy shot of mine, before mounting, for comparison. I think it was a fraction of an inch, smaller in outside diameter, than the stock tire.
- Dan
Just a heads up, usually/not always but usually when you go wider with motorcycle tires you are not going to get as much side wall. I personally didn't want the hassle of it maybe rubbing. Put a 170 on with no problems and no worries and I can bet no one looks at it and says hmmmm that guy went with a 170 instead of a 180.
