New Rear fender on my Wide Glide
Well Guys I finally started the FL conversion on my 99 Wide Glide with a new rear fender. So what do ya'll think?
https://www.hdforums.com/forum/membe...onversion.html
Next is a set of wide width extended fiberglass hard saddle bags which should be in around the 16th WOO HOO!
I took a 2009 Street Glide fender and put it on my Street Bob, had to open up my fender struts some. Still need an extension welded to the front to protect the electical components. I'm headed the same direction. Going to put a Wide Glide conversion on the front except the trees I found are 7 degree trees instead of 5 degrees. Also plan on going with Street Glide fairing, air ride and a couple of other things I'd like to make myself for it. Here it is as it sits since I'm currently in the sandbox.
Before fender adjustment and front fender
![](https://www.hdforums.com/forum/members/252792-dyna_bagger85-albums-48531-from-bobber-to-bagger-picture192354-a.jpg)
After fender adjustment...still got a ways to go
![](https://www.hdforums.com/forum/members/252792-dyna_bagger85-albums-48531-from-bobber-to-bagger-picture193906-with-my-progressive-shocks-on.jpg)
My fender is only 7" wide. I found it on eBay for $160 including shipping. You can probably find one that is wider.
Stephen Thomas Diggs
05-07-2014 09:41 PM
lilsahara450r
03-30-2010 10:30 PM
