Buyin some wheels, quick reply appreciated!
Soo I have an 07 street bob which came with the chrome spoke wheels. I've considered taking them apart and PC the hoops and hubs black, relacing etc. I've found some black w stainless spokes from an 08 dyna on a buy n sell thing here in town. I know harley changed the 1" axle to 25 mm in 08 so my question is. Do I only need to buy different bearings and they should "bolt right on"? The black wheels would come with rubber and rotors/pulley, has anyone on here done this swap before? Will I need to use my original rotors and pulley? Will the rotors and pulley even fit on the 08 wheels? I wish they weren't an hour away or I could just go look for myself, any advice would be greatly appreciated! In a nutshell, I'm wonderin what it takes to get 08 wheels on a 07 dyna.
Cheers
Cheers
the 08 wheels have single row 25 mm bearings where as the 07 has double row 1 inch bearings... youll need single row 1 inch bearings to put in the 08 wheels then everything else will work... heres a link to the bearings... also available on ebay.. just search for 6205-2RS-16 Sealed Bearing...
http://www.vxb.com/page/bearings/PROD/Kit7940
the 08 wheels have single row 25 mm bearings where as the 07 has double row 1 inch bearings... youll need single row 1 inch bearings to put in the 08 wheels then everything else will work... heres a link to the bearings... also available on ebay.. just search for 6205-2RS-16 Sealed Bearing... http://www.vxb.com/page/bearings/PROD/Kit7940
I'm also converting to newer wheels on my '07 WG. I've heard the same things about the bearing width issues. I was told I needed to convert to newer axles, spacers, etc. This would save a lot of time and money! I have the newer bearings in my garage and I measured the width, .590" which converts to 15mm, the same as the ones listed above. Really glad I looked at the forum tonight! SuperFastGlide, have you done this mod?
Thanks,
Matt
Thanks,
Matt
Yes, I have 08 crossbones wheels (originally 25mm) on my 07(originally 1 inch)
the machined recess depth on 08 wheels will only accommodate the newer style single row bearings, so its easier to just change to a 1 inch single row bearing rather than swapping axles and spacers...
