Forward control instructions
RE: Forward control instructions
your suppose to tak off the inner primary so you can get the mid control shaft out. I know some guy used a sawsall to cut it out and some tied it up behind it and left it in. If you take the inner primary off I do believe that you need special tools. Good Luck!
If you would like to keep the shift rod that goes thru the primary on. It is very easy to do. I have left mine on as tb2377 has said, you will need special tools and experience on removing the inner primary. I don't have a scanner to send you the instructions, but you might get it from the shop manual.
tdw
03-16-2017 07:59 PM
