front stock exhaust bracket?
Old 03-16-2007 | 12:52 PM
wasp's Avatar
wasp
Default front stock exhaust bracket?
put some new pipes on and dont need this (one under timer cover that has 3 screws), has anyone taken theirs off? seems to be t27 star bit screws
but gently tried and they seem like they will strip very easily. any suggestions?
Old 03-16-2007 | 01:42 PM
thrillseeker's Avatar
thrillseeker
Default RE: front stock exhaust bracket?
I have that bracket as well and have wondered how the heck to get it out of there - take the motor out of the frame is about the only thing I can think of that will give the clearance to get to those bolts.
Old 03-16-2007 | 03:03 PM
stillridin42703's Avatar
stillridin42703
painted the bracket black,,,,hard to see with the black exhaust shiels,,,,,
[IMG]local://upfiles/24177/9BD1759764A04ED7A223F500D7E90989.jpg[/IMG]
Old 03-16-2007 | 03:49 PM
EVOrider's Avatar
EVOrider
Ah, the three dreaded little torx there. Common problem on the '99-up Dyna's. They have a nasty habit of the head breaking off. If you ride a Dyna...check yours
Remove the exhaust so you see what is going on. Possibly the footpeg/brake pedal...depending on model.
The clutch cable is right in the way...so it probably needs ziptied out of the way or removed.
Unbolt the engine from the front motor mount.
Use a large heavy duty clamp and use it to clamp the engine to the frame. One end of the clamp should go on the left side of the frame and the other end should be on the left side of the motor mount. This will allow access to the bolts there and a straightshot to them. You will clear the right side portion of the frame and the midsection of the frame. The back on is still difficult to get to...but this method works.
Do not reuse those torx bolts. I don't even recommend using replacement torx either. I highly suggest replacing them with at least grade 5 with lockwasher. This is aluminum here so be easy on them...so do not overtighten.
Old 03-16-2007 | 04:29 PM
stbob's Avatar
stbob
I just left em in. Too much of a pain to get to for not much gain!
Old 03-16-2007 | 05:59 PM
soup48's Avatar
soup48
My brother and I have the same problem. We left them on, too.
Old 03-16-2007 | 10:58 PM
wasp's Avatar
wasp
think you can just grind the heads off the bolts, or is that risking too much?
Old 03-16-2007 | 11:13 PM
EVOrider's Avatar
EVOrider
I would pass on the grinding. There just really is not enough room for a grinder there. You maybe able to use a small dremel tool and grind it off. The bracket will come off, but you still have the remaining shaft of the torx hanging out...which is not really a big deal. It is easier to remove the entire torx rather than just part of it.
It really is not that difficult to shift the engine to the right. I have done this several times on different Dyna's with the Twin Cam. My FXDS-Conv. was one of them.
Old 03-16-2007 | 11:42 PM
hd2000's Avatar
hd2000
They make a special tool to take the bracket off. I think you can get it from jp cycles. its very easy with that tool.
Old 03-17-2007 | 08:51 AM
wasp's Avatar
wasp
do you have part number for tool you mention? also how long are the bolts? may have to do the move engine way.
Quick Reply: front stock exhaust bracket?
