Still looking for a good mechanic...
Old 12-14-2013, 01:25 PM
skinman13's Avatar
skinman13
skinman13 is offline
Originally Posted by stilup
http://store.ricorshocks.com/
Do some research, do search the forum and you will see so many very happy with the results.
The intiminators do work. Just a drop in if your already pulled apart.
I don't work for ricor just a believer.
I have done a lot of research on this, both talking to technicians and reading everything I can find...including searching these forums. I do not question that intiminators work as designed, it is just that it appears to me to be an expensive way to adjust preload quickly without having to pull the caps and add/subtract spacers. Form over function...sure they work, but preload is preload, no matter if it is accomplished by using expensive adjustable caps or inexpensive spacers.
Also, I wonder how many of those many very happy riders actually readjust the preload once they have it set where they like it?
Old 12-14-2013, 02:06 PM
SLV's Avatar
SLV
SLV is offline
Skin man,
The Ricor Intiminators are not preload adjusters as you described. You may be thinking of the RSD or Speed Merchant preload adjusters. The adjustoers are a bit pricy for what they do.
The Ricor products are s drop-in valve thing that forces oil through a valve at a specific rate to control the dampening process. They cost about the same as the adjusters but do a great deal more. If you plan to replace springs, you should look into these. .
Old 12-14-2013, 02:48 PM
skinman13's Avatar
skinman13
Originally Posted by SLV
Skin man,
Thanks for the correction...it looks like I need to do some more research on the Ricor Intiminators. I confused these with the devices that replaced the caps just to make adjusting preload easier. Information overload can do that sometimes.
Shootemdownace
EVO
08-26-2012 08:48 PM
dp2826
06-24-2010 08:27 PM
rounder
12-31-2008 10:27 PM
hogdvr
05-15-2008 10:02 AM
RACER
General Topics/Tech Tips
08-05-2006 10:51 AM
Quick Reply: Still looking for a good mechanic...
