Front brake hand reach to far
I looked into the Kury's but their tech told me the adjustment to move it closer was only about 1/8". After a bit of research I ended up with Oberon's. Much pricier, very high quality made in England but they brought the lever much closer. I needed mine for the clutch, and due to the price I put off getting the brake side until I saw what they were like. I'll be getting the brake lever in the spring.
Here's the link to a US seller and I'll try to post a pic where I clamped the stock lever over the Oberon so you can see the difference.
This shows the Oberon below the stock lever adjusted all the way in.
This is how the chrome finish lever looks.
Here's the link, also the one for the manufacturer.
http://www.hogleverage.com/php/products.php?cat=9
http://www.oberon-performance.com/ac...-Davidson.html
Another advantage to those levers is that they seem to require less effort, which may be due to the cam arrangement used for adjustments.
