risers and handlebar advice.
It really doesn't matter though if you're replacing both. Just make sure if you buy 1" bars, that you buy risers to fit and vice versa. You can also buy drag bars with integrated risers like t-bars but with the pull back you want. Rooti just posted some pics of his pull back drag bars. Wild 1 makes some pull back drags with risers.
If I can ask in addition to the OP's question, is it safe to change to risers to 1" from 1.25"?
I have a 2013 FXDWG and bought some 14" Outlawz from a buddy, but, they're 1" at the riser. I like the bars, but, not sure if I should get smaller risers to accommodate or just stick with 1.25" and get different bars.
If you have 1" bars that you like, just get some risers that are made for 1" bars.
It's perfectly safe. The 1 1/4" thing is, for lack if a better word, a fashion thing. They just look cool being fatter. A lot of 1 1/4" bars actually have a 1" diameter section at the riser area.
