Low Rider w/ wide glide Frt. end pics
I'll post better pics when I can get it out of the garage..but here it is. Started as an '05 Low Rider, now hasstock wide glide front end, 9" bullet headlight,deuce front rim, chrome slotted fat-boy rear rim, metzler tires, relocated indicators to console....waiting on a braided cross-over hose and I'll be able to try it out.
[IMG]local://upfiles/4574/574EFC7C71854E4CA60E6856E6B75A5A.jpg[/IMG]
[IMG]local://upfiles/4574/FF9C847A5B1A4F378956D9ACC2E50438.jpg[/IMG]
[IMG]local://upfiles/4574/FA52D82B386B4C8AB476B35CA5262AE4.jpg[/IMG]
RE: Low Rider w/ wide glide Frt. end pics
Did you use the stock indicator lights or different LED's? I am getting ready to have the same conversion to my '03 LowRider. I'm alittle heitant on the LED install. I bought 12V chrome panel led mounts , but I was told I need to put reistors for each LED, aside from the Load Equalizer. Then I was told I don't need the resistors. I am curious as to what you have done.
Thanks.
Thanks.
Thanks for the compliments, guys. This thread hassome info on my indicatorshttps://www.hdforums.com/m_1165490/tm.htmas well as how others have done it. The easiest way seems to be using the sportster or '06 dyna top clamp, but then your still stuck with the indicators on your risers, limitingbar choices.The projectreally wasn't difficult, bought the service manual, took my time....the best part is that between doing it myself and buying everything I could off e-bay it only cost me around $1200, including the new tires. Depending on what bars you go with youmight be changingyour cables, even though I kept the stock bars I didn't like routing them through the trees, keeping them behind the trees like the '06's gives it a much cleaner look.
