Dyna Horn Replacement
Gotta add a horn back to my bike and I'm considering this one: http://www.jpcycles.com/product/3600...FRRk7AodRRIAZA
I removed the stock cowbell and horn a few years ago...eyesores I didn't need covering my motor. I tucked the wires away underneath the battery and fuse boxes, which is convenient since I just moved to TX and have to put a horn back on (I thought TX was land of the free?) and figure I'll just get a tiny horn to mount under the battery box.
But I'm no electrician...having clipped the old wires, will I need to solder or anything to get them hooked back up to that little pancake?
I'm not sure how that particular horn hooks up, but I believe the stock horns just use regular old female terminal connectors to hook onto the studs on the horn. They usually crimp on. If you need to extend the wires I would just use crimp type butt connectors. I'm not very good at soldering so I tend to use crimp type connectors for everything.
You should be able to get everything you need at your local electrical supply house for less than $3. More if you need a pair of wire strippers/crimpers
EDIT
You might need 90 degree connectors.
EDIT
This might work too: http://www.dkcustomproducts.com/Blac...?categoryId=-1
I've always preferred the idea of tucking it under the battery box, out of sight, to having it up front on the down tubes.
You might consider the stock chrome horn from the Rocker or the Breakout, which mounts on the front downtubes. You might even like the way it looks.
If you're going to the trouble of putting a horn on, why not mount it somewhere where it's useful and can be heard easily?
I use mine quite a bit, and it's probably saved my azz a few times. Yup, I have loud pipes, but something about the sound of a horn gets people's attention in a special way.
When considering loudness measurements, one needs to consider how the measurements were taken, like distance from the horn, and presence or absence of sound-reflecting surfaces. Without knowing that, decibel levels don't mean much. One suppliers 100 decibel horn could be louder than another suppliers 130 decibel horn.
