drag bars on a dyna
I went a little extreme, I need something with a good pullback. I went with the Wild1 Chubby WO560. I find them a lot more comfy than my apes. Check out Wild1, the bars are well made, you cannot see the welds and they are made for the wiring to be internal. Check out their photo section to see what their bars look like on different bikes.
I got mine from Direct Cycle Parts for a great price.
What I was going to do was put on stock Fat Bob bars with a taller riser. If I eventually do anything this will be what I will do. New factory take off Fat Bob bars can be found easily and cheap. Add some slightly taller risers and you would be good to go.
Stock risers, HD fat drag bars. Never ran the stock mirrors on these bars but it shouldn't be an issue, the mirrors I'm running are much smaller and I see with them just fine
Couple more pics for reference. I like this setup a lot, I'm 6'4" and I'm sure I would be more comfortable on longer rides with a little taller bars/risers but its just not the look I want
I mentioned I put fat bob bars on my nephews FXD and loved the look...here is a pic after we turned it into a supergide tank and dash on:
Like I said in previous post...the turn signals couldn't go back on the bar (no indentations for the wires) and I really need something a tad wider for comfort and also without going to a long stem mirror. The stock mirrors work real good for seeing your shoulders. I would also like to have like 2 more inches of pullback.
I just picked up a set of 1.5" drag bars w 8" rise and 8.5" pull back. I didn't take into account the rake on my wide glide, look good but kinda puts the grips in your lap. I haven't installed them yet, just bolted them in place to see how they fit. Not sure if I'm going to go through the trouble of install to try em or not.
Found this interesting chart on what the stock bars are so you can compare new bars to it:
http://www.sideroadcycles.com/Americ...tock_Bars.html
