Jerky engine braking on '13 FB
When I'm full closed throttle decelerating and engine braking, in any gear, when I get down to around 1700 rpm, there's this sudden jerk that must be in the drivetrain somewhere, and it doesn't feel like it's good for the engine. This is the only bike where I've felt such a thing. Most bikes decel smoothly all the way down to engine idle rpm with no problems.
Cool thanks man, let me know. It does kinda feel like a slack thing, but it's done it since brand new.
When you close the throttle above 2,500 rpm, extra fuel is added. You can probably hear a change in your exhaust note. When the rpm drop below 2,000 that extra fuel is removed and it feels like the engine braking eased off somewhat. Try it a few times letting off the throttle below 2,500 and then above 2,500 and you will notice the difference. Completely normal and both of my bikes do it.
Um, always...
This. The tune changes just under 2k. Less fuel, less timing. It changes the feel of engine braking. It's usually a pretty minor change in feel and you can hear it in the exhaust. Hard to say without feeling it but that might be what you're feeling. It might be able to be smoothed out with tuning. That's about the time you should pull the clutch in anyway.
