alarm advice
Hi Mac, not sure about an 03 but on my 06 to swich off alarm so I can work on it.
disarm with 2 quick clicks of fob and switch on ignition switch as if you were going to start bike. with ignition on press and hold button on fob untill you get 3 flashes of indicator lamps, switch off ignition and press and hold button on fob untill you get 3 flashes on indicators ( on mine I also get 3 bleeps from alarm ) I can then move bike around and work on it without setting the alarm off. when you finish working on bike just double click the fob to reset alarm. Hope this helps.
there is no button on my fob.
to disable the alarm on my bike i've gotta turn the ignition to on, turn the switch to run, hold both turn signal buttons untill something flashes on the odometer, then use the left button to go through each digit then the right to submit the last digit and move onto the next, its a real PITA
cdobyns
05-14-2014 08:34 PM
scotland
05-02-2013 11:06 AM
