Mid-mount pegs with forward controls?
Old 09-25-2013 | 09:40 PM
GeorgeJ's Avatar
GeorgeJ
Real nice ride.
George
Originally Posted by zimm
I'm running forwards with mids. I rarely use the mids- on a cold morning on the highway is a good opportunity. Around town, I'm more comfy with the forwards.
Old 09-26-2013 | 09:29 AM
blueangel73's Avatar
blueangel73
Originally Posted by fogline
Blue Angel,
Thanks muchly for the pics. That looks great. Your pegs look small, almost like shift pegs.
They are shift pegs. I chopped off the ends of the stock pegs (everything the rubber covered), ground down the cut off part to make it flush with the round collar where the peg pivots, drilled and tapped a hole to receive the shift peg bolt and installed the shift pegs.
Do you ever bang your ankle at a stop?
When I first put on the forwards and left the stock mids, I would catch the mid when coming to a stop because the stuck out to far. This is why I went with the shift peg. It's shorter, still provides enough space to plant my foot and I don't hit it at all.
Do you ever ride in town with the pegs down?
The pegs never go up!!! I will ride with my feet in all kinds of positions, one on the forward the other on the mid sometimes. I am so used to it that I will take off from a stop, put my feet on the mids, pick my foot up to go shift and then come back to the mids without even thinking about it....which is handy when riding in so good twisties, muscle memory is a great thing!!! Braking is some what more of a though process when coming from the mid, need to watch the monentom carried into the pressing of the edal when coming from the mid and braking hard.
This will be mostly for long highway days, but my main concern is the midmount pegs interfering at a stop, or backing up while on the bike. Since there were no comments about that I am going to assume it is a non-issue.
I use these pegs a ton when traveling, adding the heel rest made it even better, I have the option of a forward mount, mid mount, rear (passenger) mount and I can have an open floorboard mount (heel on the mid peg and toe/ball on the forward heel rest.
As for the backing up or stopping, you are conscious of the pegs at first and notice them and will put your legs out at a wider stance until you know where you are safe. The muscle memory thing comes into effect here also, I don't even think about them or notice them once your used to them, which depends on how much you ride as to how long this will take.
EricInNCa
12-17-2013 10:02 PM
Mr. Lucky
11-26-2009 11:41 PM
NA7A
06-14-2008 10:02 AM
fxdctom
04-14-2008 04:44 PM
iwant1
08-25-2006 12:58 PM
Quick Reply: Mid-mount pegs with forward controls?
