Am I the only one?
Old 09-24-2013, 09:42 PM
roscoe2010's Avatar
roscoe2010
roscoe2010 is offline
Default Am I the only one?
Got tired of rounding out Torx head bolts and started changing them out for stainless Allen head, am I asking for more problems? I'm worried about the bolts galding. Anyone else tried this? Really frustrated with these Torx bolts.
Old 09-24-2013, 09:47 PM
kraydog's Avatar
kraydog
kraydog is offline
Replaced all of mine,anti-sieze is the key with stainless and less torque.
Old 09-24-2013, 10:04 PM
byrdman.45's Avatar
byrdman.45
byrdman.45 is offline
Been replacing Torx w/Allen heads since they started using them. Even if you use Snap-On Torx bits the head on most Torx bolts are so soft they eventually round out. Just my experience with them, but I think you are on the right track.
Old 09-24-2013, 10:16 PM
Uncle Chester's Avatar
Uncle Chester
Uncle Chester is offline
Torx head bolts blow a big one. I'm slowly phasing all mine out to stainless allen head as well.
Old 09-24-2013, 10:43 PM
Rampant's Avatar
Rampant
Rampant is offline
Is there any reason they went torx? It's annoying as hell. I just don't get it.
Old 09-24-2013, 10:46 PM
Uncle Chester
The only thing I can think of is they were cheaper to source.
Old 09-25-2013, 07:25 AM
thedonthere's Avatar
thedonthere
thedonthere is offline
I did all mine a few years ago.....no problems at all
Old 09-25-2013, 07:59 AM
ynots's Avatar
ynots
ynots is offline
I was told torx gained popularity because it was easier to use during the automation assembly process. I'd take a Allen over a torx anyday
Old 09-25-2013, 10:51 AM
chris h.'s Avatar
chris h.
chris h. is offline
I've fount that as long as I use the correct size torx bit I'm fine. Sometimes two of them are very close but one will fit perfect.
Old 09-25-2013, 10:56 AM
hvacgaspiping's Avatar
hvacgaspiping
hvacgaspiping is offline
Received 16,977 Likes on 8,636 Posts
I use a hand impact driver to loosen torx bolts. While that works well, I`m also changing to stainless allen bolts for the reasons mentioned. This is especially true for my expensive aftermarket derby cover (POW "Bring Them Home of Send Us Back") that I don`t wish to see buggered by a cheap assed torx bolt.
Quick Reply: Am I the only one?
