What Maintenance?
Old 09-21-2013 | 03:10 PM
zachpeed's Avatar
zachpeed
Default What Maintenance?
I've had my 09 Super Glide Custom about 2 months now. It had 6048 miles when I got it, and I'm at about 8220. Supposedly the dealer did the 5k mile service when it came in on service, but who knows. I know I'm coming up on an oil change soon, but besides that what other maintenance should be done now/soon?
Old 09-21-2013 | 03:33 PM
tomt's Avatar
tomt
Ride for another 1,500 miles and take it in for service. They will do the 10,000 mile service. If your going to do the service yourself, I think the owners manual has what's done at each service. 1,000, 5,000, etc.
The shop manual has instructions for all the service work.
Old 09-21-2013 | 04:13 PM
bdtaylor1979's Avatar
bdtaylor1979
I would wait till 10k and change all three fluids and plugs and air filter just to be safe. But I'm ocd when it comes to maintenance
Old 09-21-2013 | 04:15 PM
FXDWG12's Avatar
FXDWG12
You'll need the service manual to complete all the work.
Change fluids.
Clutch pac check / adjust.
Clutch lever adjust.
Check Belt tension.
Check Steering fall-away.
Check / Service air filter.
Check brake pads / fluid levels.
Check various bolts / fasteners.
Old 09-21-2013 | 07:31 PM
Two Lane Tramp's Avatar
Two Lane Tramp
Best advice I ever got was change all your fluids as often as you can afford!!! I do my oil at least every 2500, tranny and primary every 5000. Mobile 1 V twin synthetic in the motor, Drag Specialty primary oil and Royal Purple in the tranny. Fork oil every 10 K, and clutch, fork and swing arm every 30k.
Old 09-22-2013 | 06:50 AM
FXDWG12's Avatar
FXDWG12
That wasn't good advice. Your not going to hurt your engine by changing the fluids based on the OE schedual. Only thing your doing is helping the economy.
Old 09-22-2013 | 09:10 AM
ynots's Avatar
ynots
I'd change oil in all 3 holes, adjust clutch pack and cable for proper play, check critical fasteners and drive belt deflection. Buy the service manual, watch YouTube videos and avoid the stealerships like the plague. Do as much as you can yourself, let a Indy do what your not comfortable with and you will be money ahead. Don't pay a stealership for a glorified oil change
Fitz73Chrgr
General Topics/Tech Tips
05-31-2023 06:36 PM
rhj
02-26-2014 10:41 AM
The painter
06-07-2013 05:56 PM
Curt1953
08-19-2010 10:13 PM
r8rs4lf
10-16-2008 07:14 PM
Quick Reply: What Maintenance?
