2007-2012 FXDB Turn Signal Elimation/Integration
I have been searching in the forums for an answer to eliminate the stock turn signals and integrate them into the tail light assembly. I was unable to find anything. So after doing some research I came up with a way to make it work. I didn't want to use the HD relocation kit on my FXDB because I wanted to keep the clean look. The relocation kit looks horrible when saddlebags are not on the bike. So this is what I came up with. I used the Slick Signals product by CycleVisions to integrate the turn signals into the license plate cover. It was very easy to accomplish. Just drilled 1 hole through the taillight assembly to get the wires through and bolted it all together. You can get Slick Signals here: http://www.cyclevisions.com/index.ph...k-cv4611b.html
I got this trick little strip from customdynamics.com (http://www.customdynamics.com/integr...light_bars.htm). Drilled the fender for each LED. They look good.
TheChromeCollector
11-08-2010 09:29 AM
