Wyatt Floorboard Kit, Shifter Clearance Issues?
I just put on the Wyatt Floorboard Kit on Dyna. The kit comes with a one piece heel and toe shifter.
I have found that in the positions the spline allows, one position doesn't allow enough room to get your toe under the toe shifter and in the second position it doesn't allow you to up shift as the the hell shifter hits the board before it can up shift.
Anyone found a solution to this?
I have the Wyatt as well. I would be interested in somedetail as to what is different between it and the FLD kit.
As far as the shifter goes, I cut mine. However before I did I kept it heel/toe for a few weeks. One thing you can do to get better adjustment “between” spline positions is to adjust the angle by adjusting the rod between the shifter and the trans.
Rick
