Clutch Cable Swap
Clutch Cable Swap
Isaw in here somewhere about changing out the clutch cable w/o opening up the trans access cover? I would like to hear from someone with experienceas to exactly how it is done.
Is it like fishing? Or is it a pretty sure and easy thing to do. I would say I am a moderately experienced do-it-yourself'er. I'm doing a bar swap in a few days and would like to forego opening the trans cover, but will if I have to.
Thanks,
MV
Thanks,
MV
RE: Clutch Cable Swap
I would like the same thing. I'm doing my bars now too. the clutch cable is one piece. I opend the adjer section and its one cable inside. Unless there is a way to take off the eyelet and you can use the stock insides and just change the outsides.......HMMMMMMMMMMMMMMMMMMM. Anyone know?
yeah, I haven't heard of this... and from the one time I did it, I can't believe it is possible without taking off the cover.
and I secodn the internal circlip pliers... that f'er in there is a beeeooooccch. I somehow managed to do it without the pliers, but never again. I have a set now.
So I guess I'll disconect my cable from my clutch perch and have my pops hold/spin it while I unscrew the set nut on the trans case mount. Then I should be able to unhook it from the ramp hookinside the trans case from outside the trans, with out taking the trans cover off?
To replace with the new cable, I'll just fish it inside the trans until I catch the ramp hook with the cable end?
Certainly sounds do-able in theory. If it doesn't work, Iguess it's no big deal if I have to pull the case cover off, which will also mean I'll have to pull my upper pipe off.
Whenusing either one of these methods, do I lose a lot of fluid that I'll have to replace?
Thanks again ya'll for your help.
MV
MV
ORIGINAL: kzad
I just did mine last week-end ('05 fxdli), the tranny cover has to come off. I have the service manual, with that as a reference it was pretty easy. You'll need a decent set of internal snap ring pliers, the ring on the inside is pretty stiff.
