Slip ons install
Old 09-13-2013 | 02:00 PM
Wranglin4Life's Avatar
Wranglin4Life
Default Slip ons install
So I have never really wrenched on a motorcycle but I am pretty mechanically inclined. I assume the install of slip ons should be very easy correct? I have the mufflers, is there anything I need to know? Tips, tricks?
Thanks.
Old 09-13-2013 | 02:29 PM
99%r's Avatar
99%r
No tricks. Just recheck the bolts-nuts after 50-100 miles
Old 09-13-2013 | 02:31 PM
Wranglin4Life
Thanks. Hoping to get this done as soon as I get off work.
Old 09-13-2013 | 02:51 PM
seburiel's Avatar
seburiel
Out of ignorant curiosity, you don't have to mess with fuel settings, etc?
Old 09-13-2013 | 02:57 PM
deez nuts's Avatar
deez nuts
Changing the exhaust usually recquires a carb adjustment of some kind. If you have a newer FI bike then I dont really know, i'd think with just slip ons you wouldn't really have to do anything but the stock computer is probably lean anyway so you'd gain a lot by tuning it somehow.
That's all i know
Old 09-13-2013 | 03:07 PM
jimharvey1's Avatar
jimharvey1
Put some good anti-sieze compound on the inside of the mating surface of the muffler where the head pipe slips in. If you ever decide to remove the mufflers again, you will thank me for this little piece of advice.
Old 09-13-2013 | 03:12 PM
kokemill's Avatar
kokemill
Sometimes the old mufflers need gentle persuasion to be removed.
Old 09-13-2013 | 03:52 PM
Gommee's Avatar
Gommee
Devil's Advocate
If you are just putting on Slip-ons and not adding or have added bigger intake, no fuel management system needed or fuel adjustments to an EFI Bike.
Old 09-13-2013 | 07:19 PM
bdtaylor1979's Avatar
bdtaylor1979
Just changing the slip ons is pretty easy. Just 2 bolts on each muffler holding the stock exhaust bracket to mufflers and the exhaust clamp on each muffler and that's it.
As far as the other person's question....I've always been told that if all you are doing is exhaust,you don't have to do a programmer/tuner. If you open up the air intake and allow more air in then a programmer/tuner is recommended.
Old 09-13-2013 | 08:18 PM
Id.Fat Bob's Avatar
Id.Fat Bob
Been there...done that! No FI hassles and my bike sounds Purdee! Just remember, if yer using the stock clamps, to install them on the muffler first then slide over the head pipe as a unit...much easier...what I did anyway!
Quick Reply: Slip ons install
