clutch Adjustment
RE: clutch Adjustment
Like some lithum grease or something? So you geased it up in the area of the lever itself. i had it too lose before and it wouldn't return so when I changed the levers I tightend it up quite a bit more trying to get it right and no it returns fine but slips a little when I get on it.
Take the cable off of the leaver. Use a ziplock bag and a rubberband and put a small hole in your bag and slide the cable in the hole and use the rubber band to keep the bag from leaking to the cable. Use the same oil that you use in you trans and fill the bag up about 1/3 or so and zip it shut. Hang the cable so that the oil can work its way into the cable for a couple of hours.Adjust you cable so that when you let off of the lever there is about 1/16 endplay so you know your clutch is engaging all the way.
Jim
Jim
There is 1 easier way to lube your cable I just remembered. You can take your cable off from the leaver and also from your down tubes so that its only attached at the trans. Lay it flat on the ground and put a few paper towels on the lever end. The trans oil will run down the cable and come out the end slowly.It might take a few hours butI have my bike apart now and it leaks maybe a half a table spoon in 2 days from the cable laying down. LOL!
Jim
Jim
SteelCowboy
I had the same problem and lubing the clutch cable did the trick.
Don't use lithium on the cable. It is very sensitive to temperatures, especially cold and will get thick and sticky and cause problems. Try dry slide. It's posted elsewhere on the forum, or you can google for it. One of the technical writers for the HD forum suggested it. It has a graphite base product and you can order it with a long needle device to insert into the cable housing to do a good job.
good luck
good luck
You must have some free play in the cable orthe clutchwon't fully engage, that is probably what is causing the slip under acceleration. Back off the adjuster just enough to give you a bit of free-play at the lever. Btw, you can use that teflon "One lube", it is pretty slick stuff and won't thicken in cold weather and stays for a good long time---jack
