Allen bolt for brake line on bottom of neck
I had to add 3 washers to space the front brake line clamp on the bottom of the neck. Want to make sure adding the 3 washers doesn't cause a problem.
What other than hold the rubber piece and clamp for the front brake line does that Allen bolt do? Seems to be a long bolt and might do something other than just hold the brake line and clamp.
