WIRING HARNESS???
WIRING HARNESS???
Hey all, hope I can get some great suggestions from you.
I must remove my ENTIRE harness from a 2005 FXDWG!!!!!!![:'(]
Can someone give me their method of removal, whether by individually disconnecting plugs to pull thru backbone or whatever. All accessories are now completely separated from harness and it's time to pull???? I have to get my front end straightened so must remove.
If anyone has experience with this I would appreciate tips for the simplest and least destructive method.
Thanx ahead,
Rick
Thanx ahead,
Rick
RE: WIRING HARNESS???
First, you will probably have to disconnect the headlight, taillights, and the two harnesses that are wired to your hand controls on bars. Then, there is a door in front of your rear fender that leads to under the seat where much of the wiring is stored. You would probably want to pull the wire out from that spot. I would remove the battery and electrical caddy after unplugging ecm, etc... I would think that removing the harness would be the easy part, how about putting it back in there?! Good luck to ya.
ORIGINAL: thebestofindica
Hope this helps
Thanks for the suggestions. I am at the point that only 4 front connections that go thru the top tree will probably be cut (in the morn so I can sleep on it). It appears to me that all will go thru the backbone just fine if and when I can get rid of the harness wrap so I can pull the minumum of circuits at a time.
Like I stated I'll sleep on it and thanks soooo much for suggestions.
Yhis is my 12th scoot, 5th HD, and newest I ever dealt with. Technology is unGodly when it comes to circuitry.........
Thanx,
Rick
Thanx,
Rick
