Fork oil change what a pain
If you don't take the fork apart to get all the fluid out and clean the inside you are leaving stuff inside of the fork you want to remove.
It only takes a few more minutes to do it.
It really all depends on how long the oil has been in the forks and how long it has been since they were cleaned.
I do it every time. You would be surprised of how much junk is in there.
To get the oil out you have to remove the fork and pour the oil out. Trying anything else, like sucking out the oil, just leaves the worst of the **** in the bottom of the fork.
Received 4,783 Likes
For the older Dynas that you have a drain plug in the bottom of the fork it's a real easy job. A couple of tricks, 1) loosen the top fork bolt, it takes some pressure off the fork cap. 2) I bought from JP Cycles a fork cap with a allen head screw in the cap can be removed to put in the new oil with removing the whole fork cap. No caps flying off, no spring compressing, just remove the screw and put in the oil. I also replaced my stock springs with Progressive springs and use 10w Bel Ray fork oil.
Can be a bitch for sure...
Best advice I have seen here was getting up above the fork and using your body weight to press down evenly on the fork cap (after pre-marking as mentioned above). an hour into the reassembly, I can across the thread. 5 minutes later was one
Mud's fork service thread saved me an a$$load of time and frustration. An hour into the reassembly, I came across the thread, and 5 minutes later was done
I'm headed towards this shortly since I installed a new set of Ricors on the rear now the short comings of the front end are even more pronounced even though over all the ride did improve. It is obvious the forks are way too stiff and not very compliant. My thought process was to install a set of Intimitators. I would appreciate some input on whether I should also install some better fork springs like the Progressive's too.
Bob
Bob
