ape installation
ape installation
hey everybody!
I'm just curious on how easy it would be to install 12" apes on my 2013 street bob.. I wanted to go with 14" apes but i figured i will stick with 12" so i can save 1000 dollars on the installation and new cables.. I'm going to stick with the stock existing cables that are already made for the 12" apes that come with the bike.. Just curious if anyone has installed apes and grips by themselves and how easy it will be or if I should just have harley davidson install it (scared of how much they will charge me)
thanks again everyone!
nevermind finally found it on google 1" diameter... looking to be purchasing these http://store.road6customs.com/12-Ape...-BARS-0001.htm
just to confirm dyna street bobs are narrow bottoms correct
So do the 2013 Street Bobs have 12" apes or 10" ones like the past ones? When did they change them if they did?
According to this site http://www.sideroadcycles.com/Import...ckBarsOne.html
2009 and up have 12" bars... hmm never knew that.
the 2013 comes stock with 12" mini-apes. Not sure what changing them out for 12" will get you, you could save a bunch more by just leaving the 12" ones that are there... there. As for swapping them... not that easy. I just did it twice and not a fun project. The only thing worse then doing an internally wired handlebar swap??? Doing it a second time
I went with 16" apes, same style, but the bonanza bars. All stock cables and wiring. I just had to straighten out the 90 degree bend on the throttle cable. Just took re-routing the clutch cable and brake line. 12's should be no problem especially since stock is 12". Mine were 10" stock. Been running like this since 2008
