Power Commander 2006 Dyna
RE: Power Commander 2006 Dyna
I don't see anything in the 06 maps that use Samsons.....but that doesn't mean that don't have one..
I have an 07 Bob with Samson Street Sweepers and they have a map right on to what I've done....Call those guys at Dyna or email them.....I've talked to them a few times they are more than helpful
do what i did , they do have maps for similar pipes like street sweepers, straight through pipes arent gonna be much different much in performance as they will with sound,. i looked through the maps then looked online at the pipes they had maps for and chose the map with the most similar style to what i had goin on. boo ya run it and go ride. a dyno tune is the best but thats way better then nothin. again its worked again for me fine, the only thing that changed it was when weather started getting cooler but i think they have a richer cold weather map. not sure i should check though.
I'm lookin to fine tune also, I have a high flow A/C and cycle shack slip=ons. When I ordered my PCIII from fuel moto, I only had the HF A/C and stock pipes with the baffles punched out. Jamie at fuel moto put in a map before shipping. It runs great, but I think its a tad on the rich side. I also couldn't find a exact map. I am going to call them monday and see if they have something close. I'm a little leary though, its really not broke, shoudl I "fix" it?? I suppose the best way would be to have it dyno'd $$$
I have one that works good. I think the front is still a little lean. I have exactly the same set up as yours. Street sweepers and the like. Great pipes. Great sound. Good perf. They aren't actually straight through. and as long as they are you maintain back pressure enough to allow for a decent HP torque upgrade. I'll be Dynoing here before too long. If you want the map PM me with your email addy. Also It would do us justice to keep each other in the loop as far as tuning. IE if I dyno or you do please share the dynoed map. I'll be happy to send the map to yah. Again it's not perfect but it runs good and won't damage anything. you def need at least that. I have fought with dynojet about getting a wider range of maps out there but to no avail. The the 07's went and got themselves a 96 motor and mucked everything up...lol. Gonna be tough to find anthing you need for the 06. Oh well such is life.
johnebb
08-10-2008 09:15 PM
