Rear brake improvements
So I went to a victory demo ride and noticed when using the rear brake it was way better than my dyna. When I search here a lot of guys say go to lyndall and they will improve. Any thoughts on upgrading to lyndall or ebc brakes making a big difference? I just want good rear brakes as mine feel soft, or if I really jam on them they lock up.
I switched from stock to Lyndall Gold and it was like night and day. The Lyndall pads made such a difference. Before, the rear brake was about useless. Now, I think I could use just the rear and would be OK (Of course I still use the front for my main stopping power.....just saying the rear is markedly improved along with the front).
I have tried three different pads on my Fat Bob: Lyndall, EBC ordinary pads and EBC V pads. None made much difference.
I had HD check the rear brake out twice under warranty. Basically the outcome was that it was as designed, "They all do that".
Its just a bit crap as brakes go and replacing the caliper and m/c is probably the fix.
It is a well known and very successful automotive marketing strategy that if the words, "racing," or, "performance," or "Xtreme," etc., are on the label that some folks will automatically think that part is better...yet sometimes there is essentially no difference at all. Back in my aviation days, we used to love the customer who believed that the best parts cost more...our markup was usually much more as well. There were some applications where the cheaper part worked better.
While it is true that some parts are manufactured better than others, cost is not the determining factor here. Whether you choose EBC, Lyndall, or OEM replacement pads, if you choose the right pad compound for your use and keep the system inspected and maintained then you should not have any problems. Just say'n.
