exsessive valvetrain noise
So I've noticed that I've been getting a lot more noise from the motor lately. Seems to vibrate more too, and even more so when sitting on a slope. I run rendline synthetic, but its been 10,000 miles since I've started running it and never had a problem so I don't think its an oil issue. I'm just hoping my top end isn't taking a crap on me. Changing the oil this weekend so ill be looking for metal. But anyone have any ideas on what could be causing this?
What year is your bike ? 2007 and later have the newer style Hydraulic style cam chain/shoes set-up which seems to be much more reliable. I checked mine ( 2008 fxd) at 55k miles and everything looks very good. If yours is older I would certainly check the cam tensioners. You can cut open the oil filter and look through the pleats for shoe material particles.
Having said that, my top end was noisy with Synthetic oil ( singer sewing machine sound of sorts ) .I switched over to Valvolive 20-50 vee twin dino oil and use 1qt of shell rotella dino diesel oil. This for whatever reason makes my top end much quieter, and a few of my friends have switched over to this with the same results. In the winter I run straight Shell rotella diesel oil with great results, then in the spring I switch over to the 20-50 Valvolne/ Shell Rotella mix.....
I live in North West Florida where its hot and humid in summer and believe it or not it gets cold here in the winter, 30s and 40s at night. I ride 365 days a year cold and hot weather and this works great for me. Bike has 57k miles on it with zero troubles.
I usually use regular oil for a break in period on new motors then switch to synthetic oil. Conventional oil breaks down quicker and has more resistance than synthetic oil causing engines to wear quicker. The longer you wait to switch over to synthetic oil the noisier your motor will get due to loosening up from wear.
How many miles are on the engine? It might be time for a rebuild.
Before you take the engine apart have a really good look at all the bits of the exhaust and heat shields, make sure nothing is loose. Check that the exhaust isn't touching the frame anywhere. Check the front motor mount has clearance between the top of the rubber and lug on the engine. Also check for any other loose stuff like fuel tank mount bolts.
I've got about 14,700 miles on it. Been running synthetic since 5000 miles. There's a chance I might have an exhaust leak since I put my th on myself at 300 miles without changing the gaskets since they looked brand new. Maybe ill try putting new gaskets on and see if it helps. I ride it everyday except in rain. Guess ill check the tank too just incase its loose. And at 15k miles I hope it doesn't need a rebuild. The dealer probably wouldn't warranty it because I put the ac and th on myself.
