New out look on Dyna ride quality
I have had some complaints about the 10 Dyna handling since I bought it. The rough ride and the wobble on high speed turns (75 to 80). I did set the rear shocks on the fourth position and plan to add a 1.5 inch space to the forks to balance the preload with the back.
A while back I bought a 11 XL1200L from a guy in his 80's that was giving up on riding. It had 3,000 miles on it and was pristine. I ran it to 5K to do the service and then ride it to Sturgis coming up.
What I learned in that 2K miles was that the Dyna Super Glide does ride more comfortable than a XL and handles as well.
I had been used to Touring and Softails when I added the Dyna so that was my point of reference. Now, I can compare to the Sporty and realized that the Dyna is a better machine than I had thought.
This coming winter it will be my winter ride. I added a hook up for the heated gloves. Also, I will schedule it to ride to next years Sturgis.
Add a fork brace as well. Those forks look too thick to flex but they do.
I use a True Track stabilizer with fork brace and I'm pretty aggressive when the opportunity exists to grind
the pegs. I found that pre-loading the shocks did almost nothing to really help and pre-loading lowered the
rear enough that I started hitting the pipe mounting bracket.
Everyone's style and local road conditions are different, but before I went with any other changes, I'd try
either a TT or Sprueth stabilizer and fork brace with the shocks in either the first or second "click". That will
get you a long way toward where you want to go without compromising ride height and suspension travel.
Oh, yeah, I had a 2009 XL1200C that I traded in on the FXDC and while I think the Sporty is more nimble when
changing from one direction to another, the actual cornering capability is only slightly better than the Dyna;
mostly due to better peg / exhaust clearance..
I've only owned three Harleys so far, but have rented and ridden on a bunch more. I thought that all the recent ones (including softails) handled quite decently, up to the point where they ran out of cornering clearance, and started grounding hard parts. After that, it doesn't much matter. Nothing handles very well when the wheels get lifted off the pavement.
This is coming from a former hardcore sportbike rider. Modern-day Harleys really don't handle that badly, unless there's something wrong with them mechanically.
Also forgot to mention I have screaming eagle fluid in front forks. Made s huge difference, stiffer ride, doesnt bottom out, but more confidence. I recommend always upgrading for oil.
You nailed it. I went with progressive shocks and the Riccor system and could not believe the difference. I feel like I am on rails now. My bike will do 115 with zero wobble. I hate the look of the fork brace and see no need. The Tru Trak is something I am still looking into. Also made a difference when I rebuilt the swingarm. I ride in the mountains for the most part and love the way my Dyna handles.
badbs101
05-04-2007 08:47 AM
