Brake Bleeding Tip
Brake Bleeding Tip
Mentioned to a mechanic friend the front brake on my new bike needed to be bled. He shared a tip he used when he worked at a dealership. Wrap a cloth around the throttle grip and engage the brake fully. Use a long tie wrap pulled around the grip to hold the brake engaged overnight. The constant pressure will force air bubbles to work their way to the brake fluid resovoir. I tried it and it worked.
If it needs to be topped off afterwards, yes.
This is a old school trick that works.
I use a vacuum to change brake fluid or bleed and then I will do this to make sure no air is stuck anywhere. If air is in the line somewhere it can get stuck is a few areas this helps to move the air out. Banjo fittings, master cylinder air can get stuck there.
