stock risers on 13 sb?
i recently replaced my apes and put them on the stock risers. since then, i've realized that my risers themselves seem to to be rocking a bit if i pull on the bars. it's not the bars slipping, but movement where the risers meet the triple trees. it doesn't seem like the bolt underneath is loose, but it makes me nervous that something is wrong. the other day i was stopped and kinda pulled on the bars to help lift me off the seat to readjust, and they sorta pulled back a few inches, and it freaked me out so i pushed them back real quick. anyone had an issue like this before?
i was wondering if it was the rubber "giving way." that makes total sense though, and like i said it freaked me out. at first i thought it was the bars slipping, but then noticed when i pushed them back that it wasn't the bars that moved. needless to say, i rode home a bit nerve wracked...lol. anyway, thanks for confirming that. can you recommend where i can find the nylon replacements?
just go to your local moco dealer and they will be able to help you i used urethane on mine because i had the same thing happen to me it freaked me out when i was backing the bike up and my bars moved lol low and behold it was just the bushings just be sure to double check your riser bolt torque when you are done there kind of a pain to get to spec with the headlight on it
I was going to respond last night about it being the bushings, and went to a site that showed OEM parts break down to post a pic example. It showed the SB having integrated risers, and not wanting to give bad info I said nothing.
SLV, thanks for noting the change in the '13 riser set up, as the diagram was incorrect for that year.
So from last night at 9:10PM, its your bushings, replace with poly/nylon ones. OK, I feel better, now. tp dd50
I can't find my receipt with the part numbers, but they are HD brand for sure. Like $6 or $8 if I remember right.
They are polyurethane and not nylon as previously noted (by me.)
You would think that a polymer engineer would get that right! Although, nylon would work fine for this application.
