Guess I need new spark plugs
Old 07-10-2013, 09:47 PM
HBomb74's Avatar
HBomb74
HBomb74 is offline
Default Guess I need new spark plugs
These only have about 4500 miles on them. Looks like my AFR is a bit lean, too. Good thing these stock plugs aren't too expensive. I'm mostly concerned about the slight corrosion where the plug meets the head. Any similar issues? Thanks for the info
Attached Thumbnails Guess I need new spark plugs-rear.jpg   Guess I need new spark plugs-front.jpg
Old 07-10-2013, 10:55 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,056 Likes on 669 Posts
Wow that is lean. That corrosion is normal. Especially if you live in a tropical climate
Old 07-11-2013, 04:45 AM
maddghost's Avatar
maddghost
maddghost is offline
your plug shows nothing but balanced burning. The rust, well I've only seen that after about 2 years of the same plugs.
Old 07-11-2013, 05:08 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,250 Likes on 1,641 Posts
Why...?? Center electrode & ground electrode look fine so just clean them up and re-install w/some anti-sieze. 4500 miles and all you see is a little white/lean condition, but that's normal for HD's. When your plugs look like some of these (http://www.aa1car.com/library/reading_spark_plugs.jpg) then...it's time for a swap.
Old 07-11-2013, 06:21 AM
stilup's Avatar
stilup
stilup is offline
like he said, never seeze the threads slightly, they look fine.
Old 07-11-2013, 11:59 AM
nevil's Avatar
nevil
nevil is offline
Received 1,035 Likes on 773 Posts
Obviously, new plugs won't help the lean condition. They look like typical plugs from a stock motor (except for that corrosion), change them if you want, but you might want to look into something to richen things up a bit.
Old 07-11-2013, 12:08 PM
Tony P's Avatar
Tony P
Tony P is offline
Off topic, but what front fender is that? Nice looking Dyna.
Old 07-11-2013, 12:14 PM
nevil's Avatar
nevil
nevil is offline
Thanks. It's a Custom Chrome 40.
Old 07-11-2013, 04:04 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Corrosion
The corrosion (rust) on the plugs is from the water sitting in the plug wells...
Old 07-11-2013, 07:22 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
X2. Your plugs look fine. I bought my 07 dyna almost 4 months ago and my plugs had some corrosion on them likes yours. They were Harley plugs so I assumed they were the stock ones from 07 so I went ahead and changed them for peace of mind. But I am ocd about maintenance and probably over do maintenance sometimes
Quick Reply: Guess I need new spark plugs
