Dyna Low Vibration - New Dyna rider
I am considering an 07 Dyna Low Rider. I own a sporty 1200 and have test riden a Softail Deluxe. The Dyna in comparison has a lot of vibration at low speeds, sitting at idle and did not smooth out till I was really moving along. Loved the feel of the ride, not so harsh and effortless quick off the line and cruising speed but the question is:
Is this common for the Dyna, vibration i can feel even in the footpegs? I thought this vibration was somewhat toned down with rubber mounting?
Thanks
Thanks
I dont feel any vibration at idle, Id call it a visible shake. If someone has installed a engine stabilizer its apt to transfer some of that vibration thru the frame. Also as mentioned above bad motor mounts will do the same. My dyna is smoother than the 1100 Honda ace I had. If everything is set up right once your off idle your dyna should run smooth
It only had 10k miles, seems early for worn mounts but if you guys are saying it should lose any vibration once its moving then i need to test ride another to compare I'd say. Vibrating in foot pegs like a foot massager at low speeds. Does the upgrade in the engine size play into this at all?
Shaking engine? You mean her heart beat? lol yes, normal and possibly worn engine mount.
IMO, nothing beats the Twin Cam unbalance "A" engine for outright soul. Owned a Fatboy for 5 years and seriously got bored with it. Really started noticing the Dyna line and thought to myself that the bike just looks so... alive!
Almost a year on my Fat BOB and she feels alive when she is running. I like that!
