Bolt Grade Help
Old 06-19-2013, 06:59 PM
Foxknuckle's Avatar
Foxknuckle
Foxknuckle is offline
Default Bolt Grade Help
I need to replace the lower shock bolt on my FXDB with a longer one to accommodate a license plate bracket. The bolt appears to be a grade 8 bolt and the only thing I can find locally is a 12.9 hardened alloy bolt. Will this bolt work?
Old 06-19-2013, 07:03 PM
SLV's Avatar
SLV
SLV is offline
Grade 8 is a hardened alloy, but I don't recognize the 12.9 designation. It must be a Euro thing.
Let me look in my engineering cross reference book. Stand by please.
Old 06-19-2013, 07:31 PM
SLV's Avatar
SLV
SLV is offline
The 12.9 is a rating system of metric sized alloy steel fasteners. The 12.9 fasteners out perform grade 8 fasteners in yield and tensile strength. (12.9 = 160ksi yield and 177ksi tensile, the grade 8 = 130ksi yield and 150ksi tensile.)
The "alloy" steel 12.9 material is more corrosion resistant than grade 8 carbon steel too. (Carbon steel is also an alloy, so the term can be confusing.)
The Klinger rating is used for metric fasteners though. The lower shock bolt on our 2013 Street Bobs is a 1/2" x 13 American Standard.
If you have access to the correct size in a Klinger 12.9 rated alloy steel fastener, you are in good shape. It's a better fastener than a grade 8.
Old 06-19-2013, 08:20 PM
Foxknuckle's Avatar
Foxknuckle
Thanks a lot! I feel better knowing.
By the way SLV love your bike, it was one of the inspirations when buying mine.
Old 06-19-2013, 08:22 PM
SLV's Avatar
SLV
SLV is offline
Glad I could help, on both accounts! Thanks for the kind words.
Old 06-19-2013, 08:25 PM
maddghost's Avatar
maddghost
maddghost is offline
Wow SLV that is some good info right there!
Old 06-19-2013, 08:35 PM
SLV's Avatar
SLV
SLV is offline
Thanks. I learned it at the same time. In 25 years of engineering, I've never used Klinger rated fasteners. These would be great for hot rod builds. Especially 4 links and 9" rear ends.
Old 06-19-2013, 11:47 PM
latrobedyna's Avatar
latrobedyna
latrobedyna is offline
SLV i have just one ? please would a bolt that hard maybe a tad brittle for that kind a work? I recall using grade 8 bolts on high pressure hydraulic couplers and the shot would some times snap the heads right off.
Old 06-20-2013, 12:30 AM
Pistonman1's Avatar
Pistonman1
Pistonman1 is offline
I was putting a turbo on a Cat scraper today, new Cat bolts were rated 12.9, and they were SAE size (3/8-16).
Old 06-20-2013, 05:48 AM
FastHarley's Avatar
FastHarley
FastHarley is offline
Former Sponsor
Default I use them
I use those bolts for my caliper mounts I make to hold on radial mount calipers. I want to make sure they do not stretch or break. They will rust so a coating is necessary.
Quick Reply: Bolt Grade Help
