Opinions on Cams for 88"
I'm sure this topic has been hit over and over again but I'm looking for what cams you guys think run the best with an S&S Super E in an 88" Dyna without doing headwork. Looking for mostly mid-range power. I was told Andrews are the most popular, but I'm not sure which ones. This will be for street/highway riding, no drag crazyness, but I would like the max I can go within reason.
Tw 37 or 31 is a much better cam for a dyna than the 26.
- From Andrews website:
- TW26 GRIND CAMS
- Bolt-in cams for low rpm torque and two-up touring
- Add more torque and horsepower at low and middle rpm range (1800-5500 rpm)
- Work well with either fuel-injection or carburetor
- Can be used with stock valve springs and tappets
- TW31 GRIND CAMS
- Great cams for motors with 9.8 to 10.2 compression ratio
- Lower TDC lift for easy installation
- Similar to TW37 with different timing (2000-5600 rpm power range)
- Can be used with stock springs and tappets
- TW32 GRIND CAMS
- High-lift version of 31H
- Much more power through rpm range with 10:1+ compression pistons (2800-5600 rpm)
- TW37 GRIND CAMS
- Bolt-in cams for 88 in, 95 in or 96 in motors
- Smooth idle, broad torque band
- Run best with low restriction exhausts (2200-5800 rpm)
- TW48 GRIND CAMS
- Broad tip cams for baggers with stock motors; max torque at low and mid rpm ranges
- Use stock springs
- TW50 GRIND CAMS
- Maximum torque and horsepower at higher rpm ranges
- For lighter bikes and engines with a 9.5 compression ratio or higher (2600-6000+ rpm)
