Opinions on Cams for 88"
Old 06-27-2013, 01:23 PM
jcallesano's Avatar
jcallesano
jcallesano is offline
Results??
Old 06-27-2013, 06:56 PM
bigdaddy33's Avatar
bigdaddy33
bigdaddy33 is offline
If you haven't started the project, you really should reconsider the Andrews TW37. It's a great cam and a perfect match for the 88".
Old 06-27-2013, 08:40 PM
mori55's Avatar
mori55
mori55 is offline
I have the Andrews 37 G on my Deluxe nice cam, stock compression.
Old 06-27-2013, 09:10 PM
lemmeouttathiscage's Avatar
lemmeouttathiscage
lemmeouttathiscage is offline
Anyone have any idea what a cam install goes for nowdays?
Old 06-27-2013, 10:19 PM
flyin1200's Avatar
flyin1200
flyin1200 is offline
I paid $250 for the cam install and $250 for the tune.
Old 06-27-2013, 11:31 PM
lemmeouttathiscage
OK great. Thanks Flyin.
Old 06-28-2013, 09:55 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
I ran the 26 with a stock motor and it was good. Put in 37's when I did the 95 build and this thing is a rocket ship. The 26 had more power on teh low end but the 37 leaves the 26"'s in teh dust with my set up. The 37's like to be revved high. It seems like 3200- red line is where all the power is and it only takes a fraction fo second to get to 3200 rpms.
Old 06-29-2013, 11:32 AM
WhiskeyHarley's Avatar
WhiskeyHarley
WhiskeyHarley is offline
What's the difference between stock cam chain tensioners, hydraulic cam chain and geardrive?
Old 06-29-2013, 12:09 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Stock tensioners are spring loaded and wear out on the drive chains. Hydraulic utilize hydraulic oil pressure instead of springs, and gear drives utilize gears instead of chains. .003" crank run out or less for gear drives. I have switched all mine to teh Hydraulic set up as I did not want to hassle with checking the crank run out and then order my cams. Gear drives will usually give a little more power as it is more of a direct drive system.
I got the hydraulic plate here to go in my new ride I just picked up. One day soon I'll drop it in.
Old 06-29-2013, 01:44 PM
WhiskeyHarley
Gotcha I've built hot rods up and down but this is my first mechanical venture with a bike so I'm doing the cam and tensioner/chain/gear swap
Bike medic
Engine Mechanical Topics
04-25-2017 05:10 PM
Johneb48
Exhaust System Topics
07-27-2009 08:31 PM
Quickie
07-28-2007 08:19 AM
Fatboy931
EVO
07-23-2007 10:29 AM
whateva
02-21-2007 12:16 AM
Quick Reply: Opinions on Cams for 88"
