Sissy bar help
RE: Sissy bar help
The sideplates fit between the strut and the fender. There is a plate on the inside of the fender that holds on the turn signal on one end and is threaded on the other end and helps attach the chrome strut cover with a torx 45 bolt from the outside of the strut. Just pull the inner plate back, "towards the tire", and the slide in the sideplate being sure not to pinch the turn signal wire, and the push the plate back in and it will sit into the holes on the side plate. Then just screw the torx 45 bolt back in and bolt the turn signal bolt back up as well. Hopefully I didnt confuse you too much.
John
John
RE: Sissy bar help
If it's like the 06 the front bolt is easy,the rear bolt that bolts into the taillight is long enough that it's hard to remove with out lowering the tire out of the way. Best thing to do is slot out the rear bolt hole and the hole for the taillight wires so you can just drop it in place by just loosening the bolt without removing it.
Good Luck
Tom
[IMG]local://upfiles/8936/EB8EBC22D526477B82772A74F77BC2BA.jpg[/IMG]
Good Luck
Tom
RE: Sissy bar help
ORIGINAL: jbeauv
Needpictures of dynas with non detachable side plates the directions are lacking, there is a washer on my 07 fender, does it come off ?Are the plates supposed tofit flush on the fender ? Help !!!!!!
