Fat Bob issue?
Old 06-09-2013 | 02:37 AM
toku58's Avatar
toku58
Default Fat Bob issue?
I'm not sure if this is just a new bike issue but when I get on the front brake firmly then pulsate when coming to a stop. Is this normal?? Also when I'm stopped and hold the front brake, then try and compress the front forks theres a knocking sensation and sound coming from the front.
Anyone know what this could be? My bike is 2 weeks old but it's done this ever since I got it.
Old 06-09-2013 | 02:40 AM
chopNdrop's Avatar
chopNdrop
Sounds like abs issue
Old 06-09-2013 | 03:08 AM
1phaedrus's Avatar
1phaedrus
The first symptom seems to be the ABS functioning normally. The second one I find alarming, make sure the front wheel is fixed tight. Do you have play in the headset?
Old 06-09-2013 | 04:17 AM
toku58's Avatar
toku58
My buddy was thinking ABS issue also, But I don't think my bike has ABS. (I didn't pay for that option)
As far as I can tell everything is tight up front. I'm taking it to the dealer tomorrow. Hopefully they can figure it out?
Old 06-09-2013 | 04:38 AM
Xube's Avatar
Xube
Wonder if its a front disc brake issue.
Old 06-09-2013 | 04:52 AM
magazine's Avatar
magazine
When my bike got new chrome rotors it pulsated for several hundred miles, not so much anymore
Old 06-09-2013 | 05:27 AM
Foxster's Avatar
Foxster
There is a bit of a clunk from the floating brake calipers and pads that settles down after a while (or my brain is just filtering it out now). However, there are two other likely causes, both of which you want to check.
The easiest is that the fixing bolts for the fuel tank may be loose. Seems a lot of bikes left the factory with these loose. Two minute job to tighten them.
The second is that the steering head bearings were not adjusted on a lot of Fat Bobs out of the factory. This definitely creates a thunk as you describe. The fix is to adjust the "fallaway" as per the workshop manual. This involves getting the front end off the ground and swinging the front wheel gently over until it swings away on its own and measuring how far from centre that point was. Then tightening up the adjustment nut to get this fallaway happening at the right distance.
Old 06-09-2013 | 12:39 PM
toku58's Avatar
toku58
Hey thanks! I'll certainly bring these issues up to the service guys. Hopefully they will appreciate the insight! Is the floating calipers only a Fat Bob issue? Or do other Harley models have this also?
Old 06-09-2013 | 07:09 PM
HyperM3's Avatar
HyperM3
I noticed this also on my new fatbob. Doesn't necessarily happen when hard braking but when I hit small bumps. Feels like the front fork needs to be tightened a tad more. When I bring it in for service I'll mention it.
Old 06-09-2013 | 10:13 PM
Northern B's Avatar
Northern B
Had the same brake issue on mine when it was new. One of the front brake rotors was warped. It was replaced under warranty. All good ever since.
Quick Reply: Fat Bob issue?
