Need help / direction with a Rinehart exhaust bracket
Need help / direction with a Rinehart exhaust bracket / Pic's inside
I just received a used Rinehart exhaust and brackets in the mail. The bracket is totally different then what is on the bike now and I can't seem to see how it will bolt up. The current exhaust on the bike is a set of drag pipes that were installed by previous owner so I'm wondering if something was taken off when it was installed that I need to install these. If you have this bracket and could post a pic of it installed that would be great.
The exhaust Ike trying to install came off from a 2005 FXDL and I'm installing it on my 2001 so it should be comparable.
Here's some pics of the bracket.
Current exhaust bracket on bike
Thanks for any insight you can provide
Are any of the installed bolts/screws been tightened?
From the photo it looks like the bracket is too far forward at the pipe.
If you haven't try taking the exhaust pipe bolts out and line up the one engine/trans bolt that has not bolt yet.
You should not tighten any bolts until everything has been lined up and bolts/screws loose then tighten. This gives you some flexibility to have some movement to get everything lined up.
It's a 2 into 2 and have not installed anything yet. The pictures of the bike is the exhaust that's currently on it not the rinehart and the bracket I'm holding. I've just lined it up to see how it'll connect via eye balling it and can't see how it'll work. I wonder if rinehart exhausts were different in 2005? It's weird because every other manufacture list up to 2005 as the dyna changed a bit in 2006.
It really doesn't look like it lines up with the transmission properly but maybe some of the holes do? As long as a couple do just mount it.
Guess my question would be is it looks like the front pipe mounts to the bracket you have in the picture. Is there another bracket for the rear pipe?
